Interactive User Input using ArcGIS API for Python
219
a month ago
Labels (3)
MuhammadElbagoury
Hello Everyone,
I have an issue while trying to add features to a web layer published in ArcGIS Online through ArcGIS API for Python.
I want to open a map widget and add the layer to it. Then, I want to open like an edit session to add features (Polygons) interactively through the open map widget.
All this in ArcGIS Notebooks on AGOL.
Anyone can help, please??
JohnEvans6
It seems possible albeit somewhat involved:
Part 2 - Working with Geometries | ArcGIS API for Python
About halfway down is a Creating geometries interactively using the map widget section. It seems like you'll have the capture what the user draws inside the widget, copy the geometry, then append a new feature with that geometry to your layer. To fill out the metadata, you could import ipywidgets and make a few fields the user fills out
https://ipywidgets.readthedocs.io/en/stable/
