Get a specific item by user and itemType
681
5
02-08-2023 01:33 PM
JamesCrandall
MVP Frequent Contributor
I have a Notebook running in AGOL org account that is supposed to find a specific item for a user but it always returns all a list of the items of that type for the user, not the 1 item specified in they query.
items_existing = gis.content.search(query="title:SomeItemTitle, owner:someusername", item_type='PDF')
This does not return the single expected item with the title "SomeItemTitle" and returns the list of all items of type PDF for that user.
Am I not implementing this correctly?
Edit: the problem is that I NEED to delete an item with the exact title name because it will be recreated again with the same title (getting a new itemId).  What I am running into is that it cannot find the specific item by title and for some reason when it recreates the pdf item it adds on a datetime stamp into the title name.
JamesCrandall
I just tried to replicate what is found in ESRI docs for the combined query parameters.  The itemType param is outside of the first combo params for title and user, I didn't see anything for using AND condition anywhere.
I'm not totally certain that this was even a problem for my implementation at all: I was attempting to run a report off a Survey123 (which works great) but before execution the requirement was to delete any exisitng report previously created.  This was failing and causing a new report to be created with the same title but a datetime stamp was being added to the title.
To remedy I simply created another Notebook to cycle through the folder and delete any items of type pdf to guarantee none would exist the next time the generate report Notebook ran.
JamesCrandall
I think what I'm running into is that if the item title is not found then it will return a list of all items of that type for that user.
This is sort of confusing as I am expecting an empty list!
Kepa
by Esri Contributor
Hello @JamesCrandall,
I see that you use comma to separate the query. Did you try a space or AND clause?
JamesCrandall
Kepa
by Esri Contributor
Glad you've managed a workaround for it. Just to add up, here you can find query string recommendations and examples on search method in case you want to have a look.
JamesCrandall
Thank you!  This is very useful!
