Filter Services by those which contain .MapServer to get Service Manifest
121
9
09-29-2022 04:04 AM
JaymieCroucher
Hi Everyone,
Our team are trying to create a single table which creates a link between a portal item its service URL and the feature class(s) and database it sits in. Trawling the forum has led me to look at using the service manifest as a source for this for which I've had some success however I've now encountered an issue where as I loop through each Service within a folder I hit an error if the service holds no manifest. This is because geoprocessing services (e.g. A custom data export / print service) holds no manifest and so the script fails.
I've tried a TRY function and also various way of trying to create a test case to filter our non MapServer services but with little success. This is mainly as each service in the returned list isn't string but a custom ArcGIS Server data type which is limited.
Does anyone have any ideas on how to filter services?
from arcgis.gis import *
import json
gis = GIS("portal", "username", "password",verify_cert=False,)
print("Successfully logged in as: " + gis.properties.user.username)
servers = gis.admin.serverss = servers.list() #list federated servers
server1 = s[1] #isolate portal server in list
services = server1.services.list(folder="Shared") #list the services within the folder "Shared"
for service in services: #list the manifest for each service URL
     ii = service.iteminformation
     manifest = ii.manifest
     a = json.dumps(manifest)
     b = json.loads(a)
     fcnam = b['databases'][0]['datasets'] #scan the JSON and fine the list of feature classes
     dbnam = b['databases'][0]['onServerName'] # scan the JSON and find the DB name
     for x in fcnam:
          print(service,dbnam,x['onServerName']) #print service with list of db fc names
RobertAkroyd1
Hi @JaymieCroucher
I think all you need to do what you are asking above to filter on MapServer services is to add the following inside your "for service in services", e.g.
     if service.type == "MapServer":
          # the rest of your code
RobertAkroyd1
Hi @JaymieCroucher
JaymieCroucher
Very grateful Rob, worked a dream 😀
HaThach1
This script print out a few mapserver and then return this KeyError message...
File "Q:\Aqua_ArcGIS\WebServiceInfoExtract\test\test7.py", line 23, in <module>
KeyError: 'databases'
Have any idea?
RobertAkroyd1
Looks like the JSON for that service did not include a "databases" element, so you should check for that in the code first, e.g.
     b = json.loads(a)
     if b['databases']:
HaThach1
I got the same error after updating the script.
JaymieCroucher
Sorry I only recently managed to get this working in anger. The below provides a CSV output of the following:
  • Each Feature Class and sourced database provided within a service
  • The Service URL and Name
  • The Portal URL and ID
import json
import csv
import os
#Step 1 - Import all libraries and setup connection to portal and location of csv
gis = GIS("Portal URL", username, password,verify_cert=False,)
outputFile=r"\\Output CSV Location"
#Step 2 - wipe the CSV and set header values
with open(outputFile, 'w', newline='') as ResultFile:
wr = csv.writer(ResultFile)
header = 'Portal Item', 'Portal Item ID','Service URL','Portal URL','DB Name', 'Feature Class Name'
wr.writerow(header)
#Step 3 - Find hosting server and list and join all services across folders
s = servers.list()
server1 = s[0] #isolate portal server in list
services_1 = server1.services.list(folder="Server Folder Name 1") #list the services within the folder "root"
services_2 = server1.services.list(folder="Server Folder Name 2")
services_3 = server1.services.list(folder="Server Folder Name 3")
services_4 = server1.services.list(folder="Server Folder Name 4")
services = services_1 + services_2 + services_3 +services_4
#Step 4a - Isolate only MapServer services and print the manifest for each service
#Step 4b - Extract service properties from the Portal
#Step 4c - Sift through JSON from manifest and extract feature class and database
#Step 5 - Write out many to one relationship of feature class to service to portal item
b = json.loads(a)
piid = service.properties.portalProperties.portalItems
pin = service.properties.serviceName
piidi = piid[0]['itemID']
piidiurl = "Portal Map Viewer URL" + piidi
fcnam = b['databases'][0]['datasets'] #scan the JSON and fine the list of feature classes:
for x in fcnam:
with open(outputFile, 'a',newline='') as ResultFile:
ContentRow = pin,piidi,service,piidiurl,dbnam,x['onServerName']
wr.writerow(ContentRow)
loops = loops+1
print("Successfully wrote " +str(loops) + " records to the manifest CSV")
HaThach1
Hi Jamie,
I tried your script as well and got
AttributeError: 'PropertyMap' instance has no attribute 'portalProperties'
even if I comment out variable piid, now I'm getting the same error as before relate to
JaymieCroucher
Do you get a list of services from the hosting server?
Have you manually checked the JSON manifest through Server Manager for a specific service?
(Should look like: https://resources.arcgis.com/en/help/server-admin-api/serviceManifest.html. Gained through Server Manager) Example URL here: https://portal.domain/server/admin/services/ServerFolder/ServiceName.MapServer/iteminfo/manifest/man...
HaThach1
I didn't get pass this error
As for the JSON manifest check, I was able to constructed the URL from your example and see the JSON manifest of a specific service.
