Create an arcgis server folder with the python API?
232
3 weeks ago
forestknutsen1
MVP Alum
Is it possible to create an arcgis server folder with the python API within ArcGIS 10.8.1? I have tried:
gis_target = GIS(portal_url_target, portal_admin_user, portal_admin_password_target)
folder_name = "MyNewFolder"
server = gis_target.admin.servers.list()[0]
server.create_folder(folder_name)
The server object does retrieve my federated AGS. But then the call to create the folder fails.
AttributeError: 'Server' object has no attribute 'create_folder'
Clubdebambos
MVP Regular Contributor
Hi @forestknutsen1,
You're almost there with your code, from the server object you need to access the ServiceManager via the services property and then you can use the create_folder() method.
from arcgis.gis import GIS
## access Portal
portal = GIS("home") # can also use url, username, password
## get the server of interest
server = portal.admin.servers.list()[0]
## access the server ServiceManager and create folder
status = server.services.create_folder("MY_NEW_FOLDER")
print(status) # True if successful, False if a failure.
I hope that helps.
Glen
~ learn.finaldraftmapping.com
DavidSolari
I think you'll need admin access for this, then the Create Folder resource can take it from there. Can't think of a way to do this with the Python API though so you'll have to pick your preferred HTTP library and send those requests yourself.
forestknutsen1
MVP Alum
The user does have admin access. And I will look into the rest api side.
Clubdebambos
Hi @forestknutsen1,
## access Portal
I hope that helps.
Glen
forestknutsen1
MVP Alum
Ah, that did it! Thanks!
