Connection to AGOL Exception
368
6
06-20-2024 05:36 AM
BrianLeroux
I have a script i have been using for the past 6 months that connects to AGOL and copies content into my Portal. Today the script is unable to connect to AGOL. The script connects using gis = GIS(url="https://amica.maps.arcgis.com/home",username="myUN",password="myPW").
Exception                                 Traceback (most recent call last)
In  [9]:
Line 1:     gis = GIS(url="https://amica.maps.arcgis.com/home",username="myUN",password="myPW")
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\__init__.py, in __init__:
Line 637:   raise e
Line 576:   self._portal = _portalpy.Portal(
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_portalpy.py, in __init__:
Line 237:   self.get_properties(True)
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_portalpy.py, in get_properties:
Line 1312:  raise e
Line 1292:  resp = self.con.post(path, self._postdata(), ssl=True)
File C:\Users\A10713\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\arcgis\gis\_impl\_con\_connection.py, in post:
Line 1517:  raise Exception("A general error occurred: %s" % e)
Exception: A general error occurred: maximum recursion depth exceeded while calling a Python object
 When I check in Fiddler I see the following message for the request.
"After the client received notice of the established CONNECT, it failed to send any data."
Any ideas?
PierreloupDucroix
Occasional Contributor III
Hello,
you can take a look here : https://community.esri.com/t5/arcgis-utility-network-questions/install-untools-breaks-arcgis-gis-con...
I posted there because it was related to Utility Network package installation, but it may be more common.
Problem -> You need requests >=2.30.0,<2.32.0
Solution -> pip install requests==2.31.0 on the cloned environment
BrianLeroux
Oddly enough I was able to connect after changing my python package manager active environment back to the default arcgispro-py3 environment. I was using a clone as I needed a couple additional packages for another project. Not sure why the clone would block the connection to AGOL.
PierreloupDucroix
Hello,
I have the same error since I upgraded to pro 3.3, do you have the same version ?
CarlVricella
New Contributor III
Same issue since upgrading to 3.3. **bleep** ESRI, every time something gets updated; QC must be non-existent there.
ericsamson_tract
New Contributor III
Currently experiencing the same thing in a dockerized container for arcgis version: 2.2.0.1
I have not found a solution yet.
PierreloupDucroix
Hello,
BrianLeroux
That was the issue. Thanks for sharing.
