[CAN NOT RENDER MAP]
265
02-27-2024 08:36 PM
KhoaLêĐình
sr, i need your help. I have already using API keys for Arcgis in Python but i can not render a map. Can you help me to fix this problem :< 428491958_1136009070889426_8968334640804073452_n.png
KhoaLêĐình
Sorry but i follow the guide but the map is not working, how to fix this problem?  Thank you
BobBooth1
Did you specify referer?
https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html#:~:text=Usage%20Exmaple%208%3...
I see you are using Jupyter Notebook. Was this the version installed with ArcGIS Pro? You can get that version from Start>ArcGIS>Jupyter Notebooks.
You might try splitting your code into several cells and running them in sequence.
