I have an angular application that uses JS API 4.23.
When I load the map, I load some layers as not visible. When I toggle a button to display a layer, I apply a definition expression and instead the layer shows all features. If I change the definitionExpression or zoom in/out (not pan) the layerDefinition updates to its correct value.
I'm using
featLayer.definitionExpression = layerDefinition
I now have added
featLayer.refresh() after updating the definitionExpression. After adding the refresh, the first time I set the definition expression, all features show up. The second time, it flashes all features and then updates itself and works fine moving forward (for that specific layer, not others)
I also tried setting "featurelayer-snapshot-enabled": 0 as shown here:
https://codepen.io/U_B_U/pen/dyVLKaG?editors=1000 without any fixesesriConfig.workers.loaderConfig!.has = {
Is this a bug?
The layers that I load with a definition expression and visible, from the beginning work just fine.
I need to resolve this ASAP. Thanks!
