Query Feature Class with Buffer Geometry
1042
09-27-2021 11:06 AM
JohnRitsko1
New Contributor III
I'm taking the location returned from using the Search widget, passing that to create buffers around said point, then taking just a singular buffer and trying to simply query a featureClass for those PolyLines within the Buffer area.  So what I do is take the results of the search to grab the geometry of the point, pass that point and create multiple buffer rings, of which I only use 1 at this time and pass that distance to a locateBusRoutes function where I use the geometry of the 1/4 mile buffer to try and locate Bus Routes that are within this 1/4 mile (HERE IS WHERE I'M HAVING ISSUES), then it calls a function to populate a list of Bus Routes that fall within this area.  I'm in the process of converting this from 3.X API to 4.20 API and not as intuitive for me to figure out.  Any help with figuring out the issues I'm having with the Query would be great.  https://gisdev.rtcsnv.com/ADACert_4/  This is the application as I have it now.  I know that setting the layerView.watch("Updating") isn't the way to go as it will update numerous times and this clears out my results.  Your help is greatly appreciated.  Test with our address: 600 S Grand Central Pkwy, Las Vegas, NV, 89106, USA
searchWidget.on("select-result", function showLocation(evt) {
  view.goTo({
    scale: 9027
  point = evt.result.feature.geometry;
  createBuffers(point);
function createBuffers(point) {
clearGraphics();
pointLayer.add(
new Graphic({
geometry: point,
symbol: pointSym
distances = [1320, 1760, 3960];
bufferGeom = []; // Houses the buffer geometry for 1320', 1760', and 3960'
for (i=0; i<distances.length;i+=1){
const buffer = geometryEngine.geodesicBuffer(
point,
distances[i],
"feet"
bufferLayer.add(
new Graphic({
geometry: buffer,
symbol: polySym
bufferGeom[i] = buffer;
// Locates Bus Routes within 1/4 Miles 1320 Feet
locateBusRoutes(bufferGeom[0]);
function locateBusRoutes(geom) {
// Acitivates the Legend Accordian Tab
var container = dijit.byId("container");
container.selectChild("routePane", true);
// create a query and set its geometry parameter to the
// buffer circle on the view
const query = {
geometry: geom,
outFields: ["NAME", "ROUTE_NEW"]
view.when(function () {
  // Perform Query to select routes within 1/4 mile buffer area
  view.whenLayerView(busRoutes)
.then(function(layerView) {
layerView.watch("updating", async function(results) {
// do something with the layerView
layerView.queryFeatures(query).then(function(results) {
populateText(results);
// Function to populate the results as well as highlight the selected routes within 3/4 mile of point
    function populateText(results) {
        var NEWresults = [],
            listOfRoutes = [];
        for (i=0; i<results.features.length; i+=1){
            listOfRoutes.push(results.features[i].attributes.ROUTE_NEW);
            NEWresults.push('<tr><td>' + results.features[i].attributes.NAME + '</tr></td>')
        var i = 0,
            newList = "";
        if (listOfRoutes.length !== 0) {
            while (i < listOfRoutes.length) {
                if (i === 0 && listOfRoutes.length > 1) {
                    newList = "'" + listOfRoutes[i] + "', ";
                else if (i < listOfRoutes.length -1){
                    newList = newList + "'" + listOfRoutes[i] + "', ";
                else {
                    newList = newList + "'" + listOfRoutes[i] + "'";
                i++;
            busRoutes.definitionExpression = ("ROUTE_NEW NOT IN(" + newList + ")");
            selectedbusRoutes.definitionExpression = ("ROUTE_NEW IN (" + newList + ")");
            selectedbusRoutes.visible = true;
        // displays the buffer image showing buffer distances on bottom right
        document.getElementById("bufferImage").style.visibility = "visible";
        //display number of routes in extent
        document.getElementById("inextent").innerHTML = results.features.length;
        //displays the user entered address
        document.getElementById("address").innerHTML = searchWidget.results[0].results[0].name;
        //display list of points in extent
        document.getElementById("results").innerHTML = "<table><tbody>" + NEWresults.join("") + "</tbody></table>";
IhabHassan
Hi @JohnRitsko1
I got the app working, I just updated "locateBusRoutes" function to be like this
        container.selectChild("routePane"true);
let query = busRoutes.createQuery();
        query.outFields =  ["NAME""ROUTE_NEW"];
        query.geometry = geom;
        busRoutes.queryFeatures(query)
            .then(function(response){
                console.log("Here in layerView.queryFeature");
                console.log(response);
                populateText(response);
I can see the output in the results pane.
Regards
Ihab
IhabHassan
Hi @JohnRitsko1
Regards
Ihab
JohnRitsko1
New Contributor III
Thank you so much. I knew it had to be a simple solution.  Thank you again for taking the time to get this working.  Very much appreciated.
IhabHassan
all good, happy that it worked
Regards
Ihab
