popupTemplate defaultValue Arcade expression displays number value instead of text
655
12-01-2021 10:47 AM
luckachi
Occasional Contributor III
I am trying to use the DefaultValue Arcade expression within my popup but it seems like it is causing an issue with how the attribute is displayed.
If I use this:
fieldName: "CH_CHEMICALUSED2",
label: "Chemical Used #2 (Active Ingredient)",
the attribute in popupTemplate is displayed correctly
but when I try to use the DefaultValue arcade expression, to display a default value of "N/A" if there is no additional chemicals used, it reverts back to the domain number.
fieldName: "expression/defaultChem2"
expressionInfos: [{
           title: "Chemical Used #2 (Active Ingredient)",
           expression: "DefaultValue($feature.CH_CHEMICALUSED2, 'N/A')"
Tags (3)
ABishop
MVP Regular Contributor
luckachi
Thank you! 🙂
ABishop
You are welcome!  Glad you got it figure it out!
Amanda Bishop, GISP
