Can anyone point me in the right direction on how to make this code work? I have several more layers I want to add to this web app but I figured starting small and slowly scaling was the best approach @ChristianBischof @RobertScheitlin__GISP
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>LayerList widget - 4.22</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.22/esri/themes/light/main.css" />
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.12/"></script>
<script>
require([
"esri/Map",
"esri/geometry/Point",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/widgets/LayerList",
"esri/widgets/Expand",
"dojo/query",
"esri/core/watchUtils",
"dojo/dom-style"
], function (Map, Point, MapView, FeatureLayer, LayerList, Expand, query, watchUtils, domStyle) {
const watershedLabel = ({
symbol: {
type: "text", // autocasts as new TextSymbol()
color: "white",
font: { // autocast as new Font()
family: "Playfair Display",
weight: "bold"
labelPlacement: "above-center",
labelExpressionInfo: {
expression: "$feature.HRNAME"
deconflictionStrategy: "none"
const waterRend = {
type: "simple", // autocasts as new SimpleRenderer()
symbol: {
type: "simple-fill", // autocasts as new SimpleFillSymbol()
color: [0, 200, 200, 0.3],
outline: { // autocasts as new SimpleLineSymbol()
width: 0.5,
color: "black"
const watersheds = new FeatureLayer({
url: "https://gis.sccwrp.org/arcserver/rest/services/Hosted/California_Watersheds/FeatureServer",
renderer: waterRend,
title: "Watersheds",
labelingInfo: watershedLabel
const rwqcbLabel = ({
symbol: {
color: "white",
weight: "bold"
expression: "$feature.RBNAME"
const rwqcbRend = {
symbol: {
color: [0, 76, 115, 0.1],
width: 2,
color: "brown"
const rwqcb = new FeatureLayer({
url: "https://gis.sccwrp.org/arcserver/rest/services/Hosted/Regional_Water_Quality_Control_Boards/FeatureServer", // Taken from sccwrp ArcOnline account
title: "Regional Water Quality Control Boards", // naming layer as it'll be seen on the legend + layerlist dropdown menu
renderer: rwqcbRend,
labelingInfo: rwqcbLabel
// Setting up map
const map = new Map({
basemap: "satellite",
layers: [watersheds, rwqcb]
var view = new MapView({ // take that new map we just made above and display it
container: "viewDiv",
center: [-118.243683, 36.052235],
zoom: 6,
map: map,
popup: {
autoOpenEnabled: false,
dockEnabled: true,
dockOptions: {
// dock popup at bottom-right side of view
buttonEnabled: true,
breakpoint: false,
position: "bottom-right"
// Multiple layerlist function
view.when(function () {
// New Layerlist (dropdown)
// Visble layer function
// Add widget to the top right corner of the view
//workaround for making sure layerlist is ready
var layerList = new LayerList({
view: view,
listItemCreatedFunction: function (event) {
const item = event.item;
item.actionsSections = [
title: "Labels",
className: "esri-icon-labels",
layerList.on("trigger-action", function (rwqcbevent) {
if (rwqcbevent.action.id === "labels") {
if (rwqcb.labelsVisible == false) {
rwqcb.labelsVisible = true;
console.log(rwqcb.labelsVisible);
} else {
rwqcb.labelsVisible = false;
watchUtils.when(layerList, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList.domNode);
lis.map(function (li) {
if (li.innerText === "Regional Water Quality Control Boards") {
domStyle.set(li, "display", "none");
view.ui.add(layerList, "top-right");
var layerList2 = new LayerList({
view: view,
title: "Labels",
layerList2.on("trigger-action", function (watershedevent) {
if (watershedevent.action.id === "labels2") {
if (watersheds.labelsVisible == false) {
watersheds.labelsVisible = true;
console.log(watersheds.labelsVisible);
} else {
watersheds.labelsVisible = false;
watchUtils.when(layerList2, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList2.domNode);
if (li.innerText === "Watersheds") {
view.ui.add(layerList2, "top-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Your problem is in lines 165 and 206. You're excluding the layer that you actually want to include for each LayerList. By changing them to
if (li.innerText !== "Regional Water Quality Control Boards") {
and
if (li.innerText !== "Watersheds") {
you can be well-prepared for adding additional LayerLists.
and
That worked splendidly @KenBuja, much appreciation!
Attaching a working code for anyone else who might benefit from this:
<!DOCTYPE html>
<html>
<head>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script>
require([
"esri/Map",
"esri/widgets/Legend",
"esri/widgets/BasemapGallery",
"dojo/query",
"dojo/dom-style"
], function (Map, Point, MapView, FeatureLayer, LayerList, Expand, Legend, BasemapGallery, query, watchUtils, domStyle) {
// Rivers label + renderer + feature layer + add layer
const priorityLabel = ({
symbol: {
color: "white",
weight: "regular"
expression: "$feature.Actn_Rc"
const priRend = {
type: "unique-value", // autocasts as new UniqueValueRenderer()
field: "Actn_Rc",
defaultSymbol: { type: "simple-fill" }, // autocasts as new SimpleFillSymbol()
uniqueValueInfos: [{
value: "Low Priority",
symbol: {
color: "brown"
value: "Restoration & Management",
symbol: {
color: "orange"
value: "Management",
symbol: {
color: "blue"
value: "Restoration",
symbol: {
color: "green"
value: "Protection",
symbol: {
color: "yellow"
const priority = new FeatureLayer({
url: "https://services1.arcgis.com/gfvMa5URH3rFRQ7T/arcgis/rest/services/StressorRating_Statewide_Median_ReachAction_R4_1_2/FeatureServer",
title: "Watershed Prioritization Recommended Actions",
renderer: priRend,
labelingInfo: priorityLabel
// Bight layer
const bight = new FeatureLayer({
url: "https://gis.sccwrp.org/arcserver/rest/services/Hosted/Bight_Strata_2018/FeatureServer",
title: "Bight",
outFields: ["*"]
// Stations layer
let renderer = {
field: "grp",
value: "Projects",
symbol: {
type: "simple-marker",
color: "red",
outline: null
label: "Projects"
value: "Regional Monitoring",
symbol: {
color: "red",
outline: null
label: "Regional Monitoring"
const layer = new FeatureLayer({
portalItem: {
title: "Stations",
renderer: renderer,
outFields: ["*"]
// County layer
const countyLabel = ({
symbol: {
color: "white",
weight: "regular"
expression: "$feature.NAME_PCASE"
const countyRend = {
symbol: {
width: 1,
color: "white"
const county = new FeatureLayer({
url: "https://gis.sccwrp.org/arcserver/rest/services/Hosted/Counties/FeatureServer",
title: "County",
renderer: countyRend,
labelingInfo: countyLabel,
outFields: ["*"]
symbol: {
color: "white",
weight: "bold"
const waterRend = {
symbol: {
width: 0.5,
color: "black"
symbol: {
color: "white",
weight: "bold"
const rwqcbRend = {
symbol: {
width: 2,
color: "brown"
// Setting up map
layers: [watersheds, rwqcb, priority, county, bight, layer]
zoom: 6,
map: map,
popup: {
dockEnabled: true,
dockOptions: {
breakpoint: false,
// Visble LABEL function
// Function: if layerlist doesn't have exact layer name, take every other layer out of layerlist
view: view,
title: "Labels",
layerList.on("trigger-action", function (event) {
if (event.action.id === "labels") {
} else {
view: view,
title: "Labels",
layerList2.on("trigger-action", function (event) {
if (event.action.id === "labels2") {
} else {
var layerList3 = new LayerList({
view: view,
title: "Labels",
layerList3.on("trigger-action", function (event) {
if (event.action.id === "labels3") {
if (priority.labelsVisible == false) {
priority.labelsVisible = true;
console.log(priority.labelsVisible);
} else {
priority.labelsVisible = false;
watchUtils.when(layerList3, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList3.domNode);
if (li.innerText !== "Watershed Prioritization Recommended Actions") {
view.ui.add(layerList3, "top-right");
var layerList5 = new LayerList({
view: view,
title: "Labels",
layerList5.on("trigger-action", function (event) {
if (event.action.id === "labels5") {
if (county.labelsVisible == false) {
county.labelsVisible = true;
console.log(county.labelsVisible);
} else {
county.labelsVisible = false;
watchUtils.when(layerList5, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList5.domNode);
if (li.innerText !== "County") {
view.ui.add(layerList5, "top-right");
var layerList4 = new LayerList({
view: view
watchUtils.when(layerList4, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList4.domNode);
if (li.innerText !== "Bight") {
view.ui.add(layerList4, "top-right");
var layerList6 = new LayerList({
view: view
watchUtils.when(layerList6, 'operationalItems.length', function () {
var lis = query('li[aria-labelledby $= "__title"]', layerList6.domNode);
if (li.innerText !== "Stations") {
view.ui.add(layerList6, "top-right");
var basemapGallery = new BasemapGallery({ // This right here provides the gallery of basemaps users can pull from. I think.
view: view,
container: document.createElement("div")
var bgExpand = new Expand({ // This gives users the ability to choose which basemap they want to use
view: view,
content: basemapGallery
var legend = new Expand({ // not gonna lie bro, I have no idea how this creates the legend.
content: new Legend({
view: view,
style: "classic"
view: view,
expanded: true
view.ui.add(bgExpand, "top-left");
view.ui.add(legend, "top-left");
</script>
</head>
<body>
</body>
</html>
