JS API 4.X: Editor widget - FormTemplate cannot have empty array of elements
296
10-06-2022 07:26 AM
NicolasGIS
Occasional Contributor III
Dear JS API team,
I am wondering what is it not possible in the editor widget to have an empty array of elements in the FormTemplate ?
https://developers.arcgis.com/javascript/latest/api-reference/esri-form-FormTemplate.html#elements
If you set an empty array, all the attributes appear. You need to have at least one.
In my use case, I just want user to edit the geometry.
https://codepen.io/fdfdsfsdfsdfwetwg/pen/poVOEqm
In the meantime, any workaround to suggest ?
Thanks for listening !
Tags (1)
LukeCalladine
New Contributor III
Rather brute-force way but you could do the following:
      .esri-editor__panel-content__section__group{
        display:none;
Add the above to your CSS.
            const editor = new Editor({
              view: view,
              layerInfos: [pointInfos],
              allowedWorkflows: "update"
Tweak the editor with the last line of the code: allowedWorkflows: "update".
Your users will only be able to select a feature and then update its geometry - the attributes will be hidden.
NicolasGIS
Issue is still there in 4.26.
Any thought from ESRI team ? Does it look like an expected behavior @HeatherGonzago ?
