I want to update (increase / decrease) scene clipping area after I create it. My goal is to give the user ability to adjust the clipping area. I am using scene view, if that's relevent.
I've managed to update the clipping area of the map using:
const extent = view.clippingArea.clone(); view.clippingArea = extent.expand(0.5);
However when I try to set it to a specific range it does not want work:
let extent = view.clippingArea.clone(); extent.extent.xmax = 1849093 extent.extent.xmin = 1488933 extent.extent.ymax = 5921967 extent.extent.ymin = 5688179 view.clippingArea = extent
How can I set clipping area to specific range.
Hi @Serbian!
Looks like you use one level of `extents` too many in your code. Try instead:
extent.xmax = 1849093;
extent.xmin = 1488933;
extent.ymax = 5921967;
extent.ymin = 5688179;
view.clippingArea = extent;
Alternatively, you can also substitute the whole clippingArea with a new Extent at once (without cloning):
view.clippingArea = {
// autocasts as new Extent()
xmax: 1849093,
xmin: 1488933,
ymax: 5921967,
ymin: 5688179,
spatialReference: {
// autocasts as new SpatialReference()
wkid: 3857 // Make sure this is the wkid of the spatial reference your view uses!
Here's a sample app which switches between 3 different clipping extents: https://codepen.io/gsoosalu/pen/MWVPREJ
