Hello,
I have issue when add mapview using angular universal
Error when I run: npm run dev:ssr
./node_modules/@arcgis/core/widgets/support/chartUtils.js:138:12-18 - Error: export 'chartColorSets' (imported as 'n') was not found in '@esri/calcite-colors' (module has no exports)
Solved! Go to Solution.
Hi @YunusAhmadBaktir we don't currently support using SSR with the ArcGIS JS API. Here is a blog post that might provide some hints: https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/ssr-esm/.
