CORS error on Print
59
Thursday
AdrianMarsden
Regular Contributor II
CORS yet again - totally fed up now with this.
I HAVE to use API 3.11 - see Re: Measure Tool no longer gives result on mouse M... - Esri Community  due to a bug in the measure tool.
We are migrating to a new server so having fun with CORS, yet again.
Everything works until I try to print.  Then I get
esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers
No hint as to WHAT domain needs pushing.
This works if I go to the latest 3.x api.
So, I listed out what is in corsEnabledServers in the latest api and compared with what I had in 3.11 and pushed all the others in.  Still nothing.  Although I couldn't work out how to push '/^https?:\/\/.+\.arcgis\.com(\/|$)/i, ' which is present in the latest version.
Any ideas?
Cheers
ACM
AdrianMarsden
OK - sorted - sort of.
I asked myself what was different the second time around?  I even trapped the error, and in error routine called the print service again (this didn't work) but when I added a console.log(esri.config.defaults.io.corsEnabledServers) when the print function was called the second time it had one extra site in it - and this was the crucial one, in my case it was gisserver.fully.qualifed:6443 - pushing that in at startup sorts stuff
AdrianMarsden
Oh - and to make this even more annoying this error only happens the FIRST time I make a request to the CustomPrint service - if I try a second time it is fine!
AdrianMarsden
