Change BasemapGallery - Example Code ASP NET6 Angular with API
278
08-18-2022 07:51 AM
DimaY
Hello.
I am quite new to Angular. I'm very interested if there is an example project code on ASP NET 6 including Angular that could show the example described in the basemapgallery section or layers with sublayers,
Not just an example of a single html file. Namely, angular scripts and api controller examples.
Thanks!
AndyGup
Hi @DimaY we only have a basic Angular CLI example: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli. We also recommend checking out the SDK Guide topic on ES modules when working with frameworks: https://developers.arcgis.com/javascript/latest/es-modules/.
DimaY
Thanks
DimaY
And yet I will be very glad and grateful if someone has a similar code example.
I mean editing and selecting a map or map type with URL binding in ANGULAR ASP. NET6 project.
Something that looks similar Basemapgallery section or Layers with sublayers,  Surely someone has already done similar projects.
Thanks a lot!
