Basemaps, basemap gallery, base map switch, map all with my own basemaps
3008
5
11-17-2014 04:42 AM
AdrianMarsden
Regular Contributor II
OK, I am having issues getting my head round all these items whilst using my own basemaps.
In my code, I create the map object.  I do not set the basemap property.
I want to add two basemaps, a topo and photographic
I can see how to add to them to a gallery, but by that time the map object is defined, so how do I set the basemap?
I keep going round in circles - this is as far as I have got. - mainly from example code
    map = new Map("mapDiv", {
        logo: false
    var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: false,
        map: map
    }, "basemapGallery");
    basemapGallery.startup();
    var layer = new BasemapLayer({
        url: "http:/xxx/arcgis/rest/services/bmap1/MapServer"
    var basemap = new Basemap({
        layers: [layer],
        title: "Street Map",
        thumbnailUrl: "pin.gif"
     basemapGallery.add(basemap);
     var layer2 = new BasemapLayer({
         url: "http://xxx2/arcgis/rest/services/LIVEinternal/aerials/MapServer"
     var aerial = new Basemap({
         layers: [layer2],
         title: "Aerials",
     basemapGallery.add(aerial);
    console.debug(basemapGallery)
     var toggle = new BasemapToggle({
         map: map,
         basemap: "StreetMap"
     }, "BasemapToggle");
     toggle.startup();
But hit issues - what do I use in the Basemap property of the toggle - the help says "The secondary basemap to toggle to." but the ID, the title?  I've tried both and they both fail with various errors
Also, how do you get the initial basemap of the map object.
Is it just me, or does the official help really suck when it comes to daring to use your own data?
RobertScheitlin__GISP
Adrian,
  Here is a sample using custom basemaps:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title></title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
      padding:0;
  </style>
  <script src="http://js.arcgis.com/3.11/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser",
      "esri/dijit/BasemapLayer", "esri/dijit/Basemap",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser, BasemapLayer, Basemap
      parser.parse();
      map = new Map("map");
      var basemaps = [];
      var waterTemplateLayer = new BasemapLayer({
        url: "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/WaterTemplate/LocalGovernmentInfrastructu..."
      var waterBasemap = new Basemap({
        layers: [waterTemplateLayer],
        title: "Water Template",
        thumbnailUrl: "images/waterThumb.png"
      basemaps.push(waterBasemap);
      var publicSafetyLayer = new BasemapLayer({
        url: "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServe..."
      var publicSafetyBasemap = new Basemap({
        layers: [publicSafetyLayer],
        title: "Public Safety",
        thumbnailUrl: "images/safetyThumb.png"
      basemaps.push(publicSafetyBasemap);
        basemaps: basemaps,
        map: map
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style="padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
AdrianMarsden
Thanks, but that is using the gallery widget - I'm after a solution that uses the Toggle widget - I've seen a few examples and working on them now.
AdrianMarsden
This is the example I am working with
Is it possible to use BasemapToggle with custom basemaps?
But not sure how to get the map to initially work with one of my basemaps as well
Adrian,
   Ahh, I didn't read the full question.
AdrianMarsden
No problem - I'm using your code as a way of getting my basemap as the initial one.  It may work.................
