Adding popupTemplate on graphic in the sketch widget graphic layer fails at 4.21
158
11-26-2021 01:01 AM
ChristopheSuter
New Contributor III
PopupTemplate fails on the sketchWidget graphicsLayer at 4.21 here is a code sample (draw a rectangle with the rectangle tool to show popup)
4.21 (fails):
https://codepen.io/christophesuter/pen/QWMeqmo?editors=1000
4.20 (works):
https://codepen.io/christophesuter/pen/VwzoMGM?editors=100
Am I doing something wrong ? Anyone had the same problem ?
Tags (1)
JeffreyWilkerson
Occasional Contributor II
Sorry, I've tried to get a workaround but this should be working.  In the error is the message "Instance of 'esri.layers.GraphicsLayer' is already destroyed", but I can't figure out why that would be happening.  I'm thinking you should open a ticket with Esri on this one as it looks like a bug to me.
HeatherGonzago
Hi @ChristopheSuter I'm taking a look at this and will get back to you shortly.
Heather
ChristopheSuter
New Contributor III
Hi Heather,
Meanwhile I had this BUG assignment: BUG-000144839 - PopupTemplate fails on the sketchWidget graphicsLayer
Best,
Christophe
YesidLeonardoLopezSierra
Hey, there is any update on this? I made it works but I had to delete the graphic from the graphics layer and add it again but by creating a whole new polygon..
