Widget Data Extract Support TAB ??
1457
11-01-2016 11:30 PM
AhmadSopian1
whether the data extract widget support for MapInfo format?
RobertScheitlin__GISP
No there is no Map Info support.
Select data format of extracted data (based on your geoprocessing service) from the drop-down list. Available formats depend on the specific published tasks, but generally include the following:
  • File geodatabase (.gdb)
  • Shapefile (.shp)
  • Autodesk AutoCAD (.dxf)
  • Autodesk AutoCAD (.dwg)
  • Bentley Microstation Design v8 (.dgn)
