Download and visualize 3D webscene
745
09-23-2022 12:59 PM
Ed_
by MVP Regular Contributor
I would like to download and visualize the following webscene.
  1. When I click on `Open in ArcPro`, a `.pitemx` gets downloaded but, I don't know how import this file into `ArcPro`.
  2. What symbology and attribute do I need to render the trees?
  3. Does this webscene include South Florida?
OpenStreetMap 3D Trees (Realistic)
Tags (1)
Andrew--Johnson
This is a scene layer not a web scene and there are some known issues surrounding opening certain layers using this Open in ArcGIS Pro workflow.
I would recommend either adding this layer in ArcGIS Pro through the Catalog Pane Portal tab or copying the URL and going to Add Data > Add Data by Path > https://basemaps3d.arcgis.com/arcgis/rest/services/OpenStreetMap3D_Trees_Realistic_v1/SceneServer
The data in this layer is dependent on what's available in the open source OSM database. I'm not sure which area you are looking at but I looked in Miami and didn't see any trees render there so this may not work for you.
thanks,
Andrew
Andrew--Johnson
thanks,
Andrew
