stevel
'NS_ERROR_FAILURE  location: "JS frame' using v3.2 of the API
Discussion created by stevel on Oct 11, 2012
Latest reply on Oct 11, 2012 by stevel
I'm seeing a few error messages if I run this simple sample from a Mac webserver directory. I'm getting the error message below, and the map fails to load:
Error: [Exception... "Failure"  nsresult: "0x80004005 (NS_ERROR_FAILURE)"  location: "JS frame :: http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2 :: <TOP_LEVEL> :: line 15"  data: no]
Line 15
[ATTACH=CONFIG]18374[/ATTACH]
If I revert the code to use v2.8 the error messages disappear and the map loads. This code wasn't causing a problem for me previously.
The live sample doesn't cause the error message, implying that there's a problem with my web server - what should I be looking at in order to debug this? I'm not aware of having changed anything recently.
Steve
Outcomes
