"Sign In: Please Sign in to access" pop up in Map Viewer
2404
11
10-11-2012 09:23 AM
TimHayes
Occasional Contributor III
Our GIS Server, which runs Windows 2008, was updated with Microsoft's automatic updates yesterday. Now when I attempt to access my Map Services (Flex Viewer) a box pops up in the Flex Viewer that prompts me to Sign In, with the layer name, server name, and then I must enter a username and password. It was never like this before. I cannot have my users enter a username and password for all 30 layers in the viewer. Any ideas on what is wrong?
TimHayes
The error is no longer there. I cannot figure out what happened. I rebooted our server 5 times, restarted the ArcGIS Server in Components. After 45 min it works fine. Very strange.
XintaoLiu
Same here! but the error is still here!! sign...
VladislavMasatin
The same problem.
Once reboot of server helps, but today it is not helping, somethink is really wrong.
DuncanBell
I'm experiencing the same issue. I've tested with two separate servers, one over SSL and one over standard HTTP.
It happens on services that require an authenticated user, even when a valid token is supplied, and services that don't require authentication.
Has anyone found a resolution to this?
Ganael_Jatteau
Same here. I have a feature layer accessing a public service on Arcgis Online. Any solution is welcome!
MaciejSarnowski
same problem...
anybody knows the sollution?! please help!
AndrewSmart
We are also having the same problem, but seems to be isolated to feature layers. Still looking for a solution.
FrankRoberts
Can someone tell us what stimulates this response?
DanielJohns
Has anyone found a solid solution for this?..
I've called Esri and they're not able to offer any suggestions besides generate new tokens, which I have and it's still not working.
