Role Type "User" has no access using windows domain and built-in roles
478
10-08-2012 06:38 AM
GerardoGarcia
New Contributor III
When setting up security in server manager to use both windows domain and arcgis server built-in roles, no users are allowed access to services if they are setup as a role type of "User". Both "administrator" and "publisher" work, but not "User". The error returned is:
Error: User does not have permissions to access this folder.
Code: 403
[ATTACH=CONFIG]18249[/ATTACH]
I've setup IIS for windows authentication and disabled everything else. Am I missing something? Or is this a bug. Thanks for any help.
Jerry
GerardoGarcia
New Contributor III
So, after doing more research, it seems as if this really is a bug that should be addressed in SP1.
From link
http://downloads.esri.com/support/downloads/other_/189810.1_SP1_Announcement.pdf:
"NIM080829 - Authorization fails if roles are managed in the built-in store and authentication is done by the web adaptor."
Hope this helps anyone who might be having same problem.
HXiao
New Contributor III
It seems that this has not been fixed in sp1. I received the same error message in 10.1 sp1. Does anybody have a solution?
