I had converted several polygons to shapefile and merged all the shapefiles using the "mosaic to new raster" function. After merging, there were white lines at the edge of each region. I thought that the "mosaic to new raster" function would smoothen the edge?
How do I remove these lines so that the edges are uniform? I have attached the image here.
As i am still new to this software, I hope that someone can guide me along here. Many many thanks in advance.
Bernard
Bernard
You're talking about polygons (vector) and shapefiles (vector) but then you used the mosaic to new raster tool. Unless you actually want raster data, I think you should use the Merge tool.
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000055000000
Ryan
