Hello,allI am on a code migration program. I encounter some problems when I try to writethe OnMouseDown Event for a ToolButton. What I intend to do is pop out a form then let users decide layers, and then based on which layer they select, the toolbutton continues to a spatial query to do selection. Now I debug the codes I cannot select the radiobutton. I suppose maybe it is relevant to how I define and call the form, though i am not pretty sure. all the codes works well in VBA but fails in VB.net. Here are parts of the OnMouseDown codes.
Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pActiveView As IActiveView
pMxDoc = My.ArcMap.Document
pActiveView = pMxDoc.FocusMap
pMap = pMxDoc.FocusMap
Call AddDataFromFile.AddShapeFile("\\Hkhkgsv02\GIS\Basemap\Database_Index", "B1k_index")
Call AddDataFromFile.AddShapeFile("\\Hkhkgsv02\GIS\Basemap\Database_Index", "B5k_index")
Call AddDataFromFile.AddShapeFile("\\Hkhkgsv02\GIS\Basemap\Database_Index", "B10k_index")
Call AddDataFromFile.AddShapeFile("\\Hkhkgsv02\GIS\Basemap\Database_Index", "B20k_index")
Dim pScreenDisplay As IScreenDisplay
Dim pRubberEnv As IRubberBand
pScreenDisplay = pActiveView.ScreenDisplay
pRubberEnv = New RubberEnvelope
Dim pEnvelope As IEnvelope
pEnvelope = pRubberEnv.TrackNew(pScreenDisplay, Nothing)
'Rectangle Display
If pEnvelope.IsEmpty = True Then Exit Sub
With pScreenDisplay
.StartDrawing(pScreenDisplay.hDC, ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache)
.FinishDrawing()
End With
Dim pGeometry As IGeometry
pGeometry = pEnvelope
'Build a Spatial Query Filter
Dim pSFilter As ISpatialFilter
pSFilter = New SpatialFilter
pSFilter.Geometry = pGeometry
pSFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelContains
Dim frm2 As New Form2
frm2.Show()
Dim pFlayer As IFeatureLayer = New FeatureLayer
If frm2.RadioButton1.Checked = True Then
pFlayer = pMxDoc.FocusMap.Layer(FindLayerIndex.Find_Layer_Index("B1k"))
ElseIf frm2.RadioButton2.Checked = True Then
pFlayer = pMxDoc.FocusMap.Layer(FindLayerIndex.Find_Layer_Index("B5k"))
ElseIf frm2.RadioButton3.Checked = True Then
pFlayer = pMxDoc.FocusMap.Layer(FindLayerIndex.Find_Layer_Index("B10k"))
pFlayer = pMxDoc.FocusMap.Layer(FindLayerIndex.Find_Layer_Index("B20k"))
End If
MsgBox(pFlayer.Name)
'Spatial Filter
Dim pSelectionLayer As IFeatureSelection
pSelectionLayer = pFlayer
If pFlayer Is Nothing Then Exit Sub
Dim pFeatureClass As IFeatureClass
Dim pFCursor As IFeatureCursor
pFeatureClass = pFlayer.FeatureClass
pFCursor = pFeatureClass.Search(pSFilter, True)
It seems that the PFlayer is empty and the form is not okay to click radio button, it keeps poping out the message box i use for test without displaying any name. Attached is a capture of radiobuttons in the form. Jing[ATTACH=CONFIG]17755[/ATTACH]
