AkhilP
Reverse Sort method located in Symbology
Discussion created by AkhilP on Sep 17, 2012
Latest reply on Sep 21, 2012 by AkhilP
I am trying to find the Reverse Sort function using ArcObjects.
As you can see in the image below, ArcMap has the function to Reverse Sort when I right click on the words "all other values".
By performing the Reverse Sort function, the values column is sorted in a correct manner.
Right now my values section appears to be in a mixed order, 1,2,3,0,4,8. But with Reverse Sort, it will sort the values 0,1,2,3,4,8, which is what I want.
Can anyone tell me what interface and object I would need to get access to this method? Or is there an alternative.
I am using C#, VS 2010 and ArcGIS 10.
[ATTACH=CONFIG]17724[/ATTACH]
Thanks in advance.
Outcomes
