Pulling day/month/year from datetime fields
2108
09-11-2012 11:25 AM
BrittaSchroeder
Please see my attached image.
My original date field ("UTC_Time") contains thousands of unique datetime combinations and I want to have a field without the hhMMss time. I'm searching for a way to populate a field ("Day_Month_Year") to have a format similar to dd/mm/YYYY ("Flight_Date"). Since I want my attribute table to have fields with both date/time and just date, I don't want to change just the formatting of my OS. I was able to create a string field ("Flight_Date") but this doesn't serve my needs for further date calculations. Searching the Python tutorial, this is the best code I could conceive with my limited Python knowledge. I don't want to be that person who asks for someone to write my code, I would just appreciate being put on the right track. Thanks.
[ATTACH=CONFIG]17609[/ATTACH]
JakeSkinner
Esri Esteemed Contributor
Hi Britta,
You can use the following calculation in the field calculator (be sure 'Python' is checked at the top).  This will work for a field of type Date.
!UTC_Time!.split(' ')[0]
JakeSkinner
Hi Britta,
BrittaSchroeder
Jake-
Thanks! Worked like a charm!
Britta
