pramodharithsa
Accessing Drawing Info
Discussion created by pramodharithsa on Sep 6, 2012
Latest reply on Sep 6, 2012 by geos_rfleet
Is there a way to access the drawing info of layers.?
I use a ArcGIS server Version 10.0
[ATTACH=CONFIG]17514[/ATTACH]
I see only these set of properties accessable with layerinfos
[--EDIT--]
From the doc's i see
If the layers are version 10 or lower the legend is created using the ArcGIS.com legend service. In order to use the ArcGIS.com legend service your map service needs to be publicly accessible and your application must be able to access ArcGIS.com.
There is similar dependancy on Drawing Info as well i guess.
(In my case map service is not publicly available)
Outcomes
