We have an issue with replication in a disconneted environment. We're running ArcGis 10 sp3 on Oracle 11.2.0.3.0 We have multiple replicas set up that has been running for several months.
Our problem occures when we try to import a data change message. We can export the message perfectly ok, but when we try to import it again we get following message:
Import Changes failed.
Generation numbers are out of order
(and then a list of messages saying Version not found... (see attached screenshot))
There is no difference either we use xml or file geodatabase for the datachange message. The result is the same either way.
Any idea why this suddenly start to happen and how to fix it?
Also, we have synchronized this replica many many times before this started to be a problem, so something strange is going on here...
BR
Tore
BR
Tore
For instance in the Replica I am trying to import an .xml message to says the generation is 3 and the .xml message I tried to import has a generation of 6. Therefore there should be two other .xml message files that were never imported/received on my side.
As for the version part, make sure the version you created when you first created the replica is present. I always use DBO from our SDE so that other people in our company can import messages just in case I'm not around to do so and I guess that's just a better way to go. If you didn't do that to begin with when you created the replica I'd think it's too late for that. But just make sure the version is created with the same name and under the same account username as when you created the replica.
Hope this helps!
Jeanetta
