Help me please. ArcGIS SDK Android install problem error
2703
6
08-15-2012 04:38 AM
BunditHirunkarn
I use guide http://resources.arcgis.com/en/help/android-sdk/concepts/index.html#//01190000002m000000
This image Problem
[ATTACH=CONFIG]16969[/ATTACH]
Help me Thank you very much
JoeHue
deleted-user-ATjHIWsdQYmT
Occasional Contributor III
Try extracting the zip file contents to the root of your local drive in a folder called "ArcGISAndroid" or something like that.  Then install the jar's from there.
BunditHirunkarn
I move file zip to C:\ArcGISAndroid
[ATTACH=CONFIG]16995[/ATTACH]
same problem install.
I test extract file zip error
[ATTACH=CONFIG]16996[/ATTACH]
I download new zip file error same.
I think zip file error,  I would like new zip file
You upload new zip file please.  Like download
Thank you.
Might be an issue with the Esri download.  I'd suggest contacting Tech Support.
Another thing to try would be associating zip files with something other than WinRAR.  Maybe try associating zip's with the default Windows utility.  Not sure if it'll make a difference, but it's worth a try.
JoeHue
I have the same error, is there someone have solved this? please help us...
JoeHue
SumitSharma
New Contributor III
Please try the following steps:
1. Start Eclipse, then select Help > Install New Software....
2. Click Add, in the top-right corner.
3. In the Add Repository dialog that appears, enter "ArcGIS 4 Android Plugin" for the Name then click the "Archive" button (not local) and navigate to the .zip file that was downloaded.
Cheers!!
Sumit
