I am attempting to add some functionality to the basic points to line tools script that will allow for a new optional parameter that will limit the maximum distance between points to draw a line.I took the code and converted it to arcpy v10.0 just so everything is on the same page, and that worked fine. I am just having a bit of trouble figuring out the best way to go about the next step. Would it be best to check if each point is a certain euclidean distance from the previous point, or after the lines have all been drawn, to simply split the feature at line lengths above the threshold.Any input would be appreciated, I've pasted the code below as well as attached it with the script tool parameters.import arcpy
import os
#import types
def convertPoints():
# Input point FC
# Output FC
# Feature Field
# Sort Field
# Close Line or Leave Open
# Max line length to join
inPts = arcpy.GetParameterAsText(0)
outFeatures = arcpy.GetParameterAsText(1)
IDField = arcpy.GetParameterAsText(2)
sortField = arcpy.GetParameterAsText(3)
closeLine = arcpy.GetParameterAsText(4)
maxLine = arcpy.GetParameterAsText(5)
if IDField in ["", "#"]: IDField = None
if sortField in ["", "#"]:
cursorSort = IDField
else:
if IDField:
cursorSort = IDField + ";" + sortField
else:
cursorSort = sortField
#if types.TypeType(closeLine) != types.BooleanType:
if type(closeLine) != bool:
if closeLine.lower() == "false":
close = False
else:
close = True
if maxLine in ["", "#"]:
maxLine = None
else:
if type(maxLine) == float:
maxLine = float(maxLine)
elif type(maxLine) == int:
maxLine = int(maxLine)
convertPointsToLine(arcpy, inPts, outFeatures, IDField, cursorSort, close, maxLine)
def enableParam(hasMZ):
if hasMZ:
return "ENABLED"
else:
return "DISABLED"
def convertPointsToLine(arcpy, inPts, outFeatures, IDField, cursorSort, close, maxLine):
try:
# Assign empty values to cursor and row objects
iCur, sRow, sCur, feat = None, None, None, None
desc = arcpy.Describe(inPts)
shapeName = desc.ShapeFieldName
# Create the output feature class
outPath, outFC = os.path.split(outFeatures)
arcpy.CreateFeatureclass_management(outPath, outFC, "POLYLINE", "",
enableParam(desc.hasM),
enableParam(desc.hasZ),
inPts)
# If there is an IDField, add the equivalent to the output
if IDField:
f = arcpy.ListFields(inPts, IDField)[0]
tMap = {'Integer': 'LONG', 'String': 'TEXT', 'SmallInteger': 'SHORT'}
fType = f.type
if tMap.has_key(fType):
fType = tMap[fType]
fName = arcpy.ValidateFieldName(f.name, outPath)
arcpy.AddField_management(outFeatures, fName, fType, f.precision, f.scale, f.length,
f.aliasName, f.isNullable, f.required, f.domain)
# Open an insert cursor for the new feature class
iCur = arcpy.InsertCursor(outFeatures)
sCur = arcpy.SearchCursor(inPts, "", None, cursorSort, cursorSort)
#sRow = sCur.Next()
# Create an array and point object needed to create features
array = arcpy.CreateObject("Array")
pt = arcpy.CreateObject("Point")
# Initialize a variable for keeping track of a feature's ID.
ID = -1
for sRow in sCur:
pt = sRow.getValue(shapeName).getPart(0)
if IDField:
currentValue = sRow.getValue(IDField)
else:
currentValue = None
if ID == -1:
ID = currentValue
if ID <> currentValue:
if array.count >= 2:
# To close, add first point to the end
if close:
array.add(array.getObject(0))
feat = iCur.newRow()
if IDField:
if ID: #in case the value is None/Null
feat.setValue(IDField, ID)
feat.setValue(shapeName, array)
iCur.insertRow(feat)
else:
arcpy.AddIDMessage("WARNING", 1059, str(ID))
array.removeAll()
array.add(pt)
ID = currentValue
# Add the last feature
if array.count > 1:
if close:
if IDField:
feat.setValue(IDField, currentValue)
else:
array.removeAll()
except Exception as err:
arcpy.AddError(err.message)
finally:
if iCur:
del iCur
if sRow:
del sRow
if sCur:
del sCur
if feat:
del feat
if __name__ == '__main__':
convertPoints()
