joosthoek
Lines between points at high latitudes do not seem to follow great circle in ArcGlobe
Discussion created by joosthoek on Apr 19, 2012
Dear all,
I made a polygon shapefile consisting of 20 triangle polygons (geodesic grid). See the attachment zip file. Each polygon should be the same size and all 20 together cover the globe.
When I look at the shapefile in ArcGlobe at high latitudes the triangle's become rounded and do not seem to follow a great circle.
I would like to do things like intersections, and I noticed that this is not only a visualization issue. I tried to select the triangle polygon overlaying a certain point and the wrong polygon is selected.
Is this solvable or is this maybe a bug?
Thanks in advance,
Jelmer
Outcomes
