ramakan
Cannot select feature with Select Feature tool but can select in attribute table
Discussion created by ramakan on Jul 29, 2010
Latest reply on Jul 24, 2012 by Ahakimy
Hi, I have a recurring problem. In ArcMap 9.3, no features are selected when I try to use the Select Features tool. The shapefile is, in fact, enabled in the Set Selectable Layers dialog. If I open the attribute table and select a feature there, the feature becomes selected in the map display. I have tried restarting ArcMap, starting from a blank document, different shapefiles, restarting the  computer.  I even deleted the Application Data\ESRI folder in my Windows user profile, but the issue does not go away.
Outcomes
