ah1508
Exporting SDE Schema to XML
Discussion created by ah1508 on Apr 13, 2012
Latest reply on Apr 16, 2012 by ah1508
I'm trying to create an XML schema document from an SDE database (I'm trying to do this http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//0093000000sz000000 programatically).  I used the example code http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_export_a_dataset_to_XML/000100000m8p000000/, but I keep getting the attached error at this line:
geoDBDataTransfer.GenerateNameMapping(enumName, workspaceName, enumNameMapping)
I think it may have to do with Dataset.Fullname not being populated with SDE data, but I don't know.
Dim factoryType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory")
Dim workspaceFactory As IWorkspaceFactory = CType(Activator.CreateInstance(factoryType), IWorkspaceFactory)
Dim workspace As IWorkspace = workspaceFactory.OpenFromFile(fileGdbPath, 0)
Dim workspaceDataset As IDataset = CType(workspace, IDataset)
Dim workspaceName As IName = workspaceDataset.FullName
Does anyone have some insight as to what I'm doing wrong, and how to make it work for an SDE database?  It works just fine with a file geodatabase.
Stacie
[ATTACH=CONFIG]13516[/ATTACH]
Outcomes
