fabpuddu
How to use Billboard Symbol with IFeatureLayer (GlobeControl)
Discussion created by fabpuddu on Apr 2, 2012
Latest reply on May 21, 2012 by fabpuddu2
I'm trying to use a billboard symbol from style gallery in globecontrol using IFeatureLayer
but I have a problem, the symbol is showed like a rectangle and not show lik billboard
In attachments the image of my result
I can manage style gallery symbols using IFeatureLayer ? How I can do ?
thanks
This is my code:
Private m_objGlobeControl As AxGlobeControl
Private m_FeatureLayer As IFeatureLayer
Public Sub AddFeature(ByVal stDati() As st_DataTarget_3d)
        Create_Layer()
        AddingFeature(stDati)
        m_objGlobeControl.GlobeDisplay.RefreshViewers()
End Sub
Private Sub Create_Layer()
        Dim pFeatureClass As IFeatureClass
        pFeatureClass = CreateFeatureClass(esriGeometryType.esriGeometryPoint)
        Dim pFLy As IFeatureLayer
        pFLy = New FeatureLayer
        With pFLy
            .FeatureClass = pFeatureClass
            .Name = m_NameLayer
            .Cached = True
            .Selectable = True
        End With
        Dim pSymbol As ISymbol = LoadStyleSymbol()
        Dim pColor As IColor = New RgbColor
        pColor.RGB = RGB(0, 255, 0)
        pColor.Transparency = 255
        Dim markerSymbol As IMarkerSymbol = TryCast(pSymbol, IMarkerSymbol)
        markerSymbol.Color = pColor
        markerSymbol.Size = 15
        Dim pRend As IFeatureRenderer
        Dim pSimpleRend As ISimpleRenderer
        Dim pGeoFL As IGeoFeatureLayer
        If Not IsNothing(pSymbol) Then
            pRend = New SimpleRenderer
            pSimpleRend = pRend
            pSimpleRend.Symbol = markerSymbol
            pGeoFL = pFLy
            pGeoFL.Renderer = pRend
        End If
        m_objGlobeControl.Globe.AddLayerType(pFLy, esriGlobeLayerType.esriGlobeLayerTypeDraped, True)
        m_FeatureLayer = pFLy
End Sub
Private Sub AddingFeature(ByVal stDati() As st_DataTarget_3d)
        Dim pFeatureClass As IFeatureClass = Nothing
        Dim pFeature As IFeature = Nothing
        Dim pPoint As IPoint
        pFeatureClass = m_FeatureLayer.FeatureClass
        pFeature = New Feature
        For iConta As Integer = 0 To (stDati.Length - 1)
            If Not IsDBNull(stDati(iConta).Latitudine) And Not IsDBNull(stDati(iConta).Longitudine) Then
                pFeature = pFeatureClass.CreateFeature
                pPoint = New Point
                pPoint.PutCoords(stDati(iConta).Longitudine, stDati(iConta).Latitudine)
                Dim za As IZAware = TryCast(pPoint, IZAware)
                za.ZAware = True
                pPoint.Z = 25
                With pFeature
                    .Shape = pPoint
                    .Store()
                End With
            End If
End Sub
Private Function CreateFeatureClass(ByVal TipoGeometria As esriGeometryType) As IFeatureClass
        Dim pFWS As IFeatureWorkspace = Nothing
        Dim pWorkspaceFactory As IWorkspaceFactory
        Dim pWorkSpaceName As IWorkspaceName
        Dim pName As IName
        Dim pFields As IFields
        Dim pFieldsEdit As IFieldsEdit
        Dim pField As IField
        Dim pFieldEdit As IFieldEdit
        Dim pGeomDef As IGeometryDef
        Dim pGeomDefEdit As IGeometryDefEdit
        Dim pFeatClass As IFeatureClass
            pWorkspaceFactory = New FileGDBWorkspaceFactoryClass()
            pFWS = pWorkspaceFactory.OpenFromFile(My.Application.Info.DirectoryPath & "\FGDB\NEMO-TMP-FGDB.gdb", 0)
            Dim pEnumDS As IEnumDataset = TryCast(pFWS, IWorkspace).Datasets(esriDatasetType.esriDTFeatureClass)
            Dim pDS As IDataset = pEnumDS.Next
            Do Until pDS Is Nothing
                If pDS.Name = m_NameLayer Then
                    pDS.Delete()
                    Exit Do
                End If
                pDS = pEnumDS.Next
            Loop
            pFields = New Fields
            pFieldsEdit = pFields
            pField = New Field
            pFieldEdit = pField
            pFieldEdit.Name_2 = "OID"
            pFieldEdit.Type_2 = esriFieldType.esriFieldTypeOID
            pFieldsEdit.AddField(pField)
            pField = New Field
            pFieldEdit = pField
            pFieldEdit.Name_2 = "Shape"
            pFieldEdit.Type_2 = esriFieldType.esriFieldTypeGeometry
            pGeomDef = New GeometryDef
            pGeomDefEdit = pGeomDef
            With pGeomDefEdit
                .GeometryType_2 = TipoGeometria
                .SpatialReference_2 = TryCast(m_objGlobeControl.Globe, IBasicMap).SpatialReference
                .HasZ_2 = True
            End With
            pFieldEdit.GeometryDef_2 = pGeomDef
            pFeatClass = pFWS.CreateFeatureClass(m_NameLayer, pFields, Nothing, Nothing, esriFeatureType.esriFTSimple, "Shape", "")
            CreateFeatureClass = pFeatClass
End Function
Private Function LoadStyleSymbol() As ISymbol
        Dim styleGallery As IStyleGallery = New ServerStyleGalleryClass()
        Dim styleStorage As IStyleGalleryStorage = TryCast(styleGallery, IStyleGalleryStorage)
        styleStorage.TargetFile = "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle"
        styleStorage.AddFile("C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle")
        Dim enumStyleGalleryItem As IEnumStyleGalleryItem = styleGallery.Items("Marker Symbols", "C:\Programmi\ArcGIS\Engine10.0\Styles\3D Billboards.ServerStyle", "")
        enumStyleGalleryItem.Reset()
        Dim styleItem As IStyleGalleryItem = enumStyleGalleryItem.Next()
        While (styleItem IsNot Nothing)
            If styleItem.Name = "Red Pushpin 3" Then
                Exit While
            End If
            styleItem = enumStyleGalleryItem.Next()
        End While
        Dim pSymbol As ISymbol = TryCast(styleItem.Item, ISymbol)
        Return pSymbol
End Function
Outcomes
