I'm fairly new to python and arcpy. I'm picking it up quickly, but I've hit a wall on a script I'm working on. Here's the issue:
I'm trying to write a script to loop through each record in a feature class, export each record as a layer, save the layer as a layer file (so I can symbolize it), and then symbolize it.
I've got this working fine in my "test" mode (without using variables); however, when I add variables to act as parameters for the tools I'm using, I run into a problem. Specifically, it's the SaveToLayerFile_management() tool that's giving me this error:
...[previous code, see attachment for full code]...
arcpy.MakeFeatureLayer_management(srcFeature, inLayer, whereClause) #creates the layer based on crop type
arcpy.SaveToLayerFile_management("\"" + inLayer + "\"", "\"" + inLayer + "_layer\"") #should save the layer as croptype_layer. Syntax is fine as far as I can tell.
Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000732: Input Layer: Dataset "Corn" does not exist or is not supported
"Corn" does exist! When I enter this into the python window...
arcpy.SaveToLayerFile_management("Corn", "Corn_layer")
...it recognizes "Corn" and runs it fine.
Any help would be very much appreciated. This is driving me crazy!
-Cal
p.s. I'm running this code in the Python Window in ArcMap 10, if that matters.
