ecohydrologist
how to fire code only when editor first starts (and not when edits are saved/stopped)
Discussion created by ecohydrologist on Feb 23, 2012
Latest reply on Feb 24, 2012 by ecohydrologist
I think I must be missing something obvious and fundamental...
I need to know how to fire a procedure (Private sub LoadTableNameArrayFromDB) ONLY when an editing session begins.
I have tried:
  • Including a call to the procedure from editorevents_onstartediting which results in the procedure firing every time edits are saved or closed (not acceptable) as well as when an editing session begins.
  • Listening to "save edits" and "stop editing" actions and setting a boolean variable to true only if the user is stopping edits. My idea was that when this same boolean var was read in the editorevents_onstartediting in the next editing session, the procedure would fire appropriately. However the boolean variable value did not persist between edit sessions.
I am surely missing something obvious about gettting non-object, global variables to persist outside an edit session, since plenty of code is written outside editing sessions.
My customization is complete except for this issue. Please help! My customization includes 2 forms and 6 modules grouped by module actions (such as loading arrays, entry validation, data upload, database connection, etc) and is written in vba in ArcGIS 10 using an Oracle 10 sde geodatabase.
Outcomes
