Cannot find the input table or query 'GDB_RasterColumns'
3384
02-16-2012 07:18 AM
MilesHitchen
We are trying to reconcile a checked out PGDB (ArcGIS 9.3) into it's parent PersonalSDE database (SQL Server Express 2005) and get the following error:
[ATTACH=CONFIG]12012[/ATTACH]
Synchronize Replica failed
Reconcile failed during replication synchronization. [Check in succeeded but reconcile and post with parent version in the master geodatabase failed.]
The Microsoft Jet database engine cannot find the input table or query 'GDB_RasterColumns' Make sure it exists and that it's name is spelled correctly.
The PGDB or PersonalSDE database ever contained any raster datasets, so we're quite confused as to why this message is being displayed. A search of the Archive Forums gave this link http://forums.esri.com/Thread.asp?c=93&f=2371&t=279426 but there were no solutions or suggestions.
Has anyone else had these problems recently or managed to solve the issue?
Thanks in advance,
Miles.
JakeSkinner
Esri Esteemed Contributor
Hi Miles,
It appears the error is caused during the reconcile/post operation.  You should have a version that was created in the SDE geodatabase when the data was checked back in.  Do you receive an error when you try to reconcile and post this version using the versioning toolbar in ArcMap?
