gilest
How do I remove the Add/Delete/Update links at the bottom of a FeatureLayer URL?
Discussion created by gilest on Jan 13, 2012
Latest reply on Jan 20, 2012 by rnarayanan-esristaff
I have security enabled on my ArcGIS server and a very limited # of users who can access FeatureServices, but I'd like to set it up so no one can edit a FeatureService Layer through the links at the bottom of the REST endpoints (e.g. http://myserver/arcgis/rest/services/aservice/FeatureServer/0, "Supported Operations" links at the bottom).  Is there a way to disable or remove these links?  If so, which config file do I need to edit?  If this is not possible, is turning off the entire Services directory the only other option?
Terry
Outcomes
