dhofer
mps atlas.exe export not working correctly
Discussion created by dhofer on Dec 13, 2011
Latest reply on Dec 15, 2011 by dhofer
I've been using the following code since 9.3 and now I'm on 10 and you can see the atlas.exe program bombs out part way through.  I've tried this with a fresh reboot.  Typically I've broken up the export process into 3 or 4 different .bat files but I feel I shouldn't have to do this.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\dahofer>d:
D:\>cd D:\GIS_Projects\2012\DD\WR\MapFiles\MXD
D:\GIS_Projects\2012\DD\WR\MapFiles\MXD>"C:\Program Files\ESRIProductionMapping\
Desktop10.0\Bin\atlas"  /export /dpi:300 /export: /oiq:3 /exportpath:"D:\GIS_Pro
jects\2012\DD\WR\Products\DD_PDF_Binder\ExportHolding" /exporter:PDF /mxd:"ALB.m
xd" /mxd:"ALWE.mxd" /mxd:"BMSB.mxd" /mxd:"CLB.mxd" /mxd:"EAB.mxd" /mxd:"EGVM.mxd
" /mxd:"GH.mxd" /mxd:"GH_Melanoplus_Sanguinipes.mxd" /mxd:"GM.mxd" /mxd:"GWSS.mx
d" /mxd:"JB.mxd" /mxd:"LBAM.mxd"  /mxd:"MC.mxd"  /mxd:"MXFF.mxd" /mxd:"SFTM.mxd"
/mxd:"SL.mxd" /mxd:"SYM.mxd"
Map Document : ALB.mxd
Exporting Map Series [1] : _
   Exporting Map Sheet [1] : Arizona
   Exporting Map Sheet [2] : Arkansas
   Exporting Map Sheet [3] : California
   Exporting Map Sheet [4] : Colorado
   Exporting Map Sheet [5] : Idaho
   Exporting Map Sheet [6] : Iowa
   Exporting Map Sheet [7] : Kansas
   Exporting Map Sheet [8] : Louisiana
   Exporting Map Sheet [9] : Minnesota
   Exporting Map Sheet [10] : Missouri
   Exporting Map Sheet [11] : Montana
   Exporting Map Sheet [12] : Nebraska
   Exporting Map Sheet [13] : Nevada
   Exporting Map Sheet [14] : New Mexico
   Exporting Map Sheet [15] : North Dakota
   Exporting Map Sheet [16] : Oklahoma
   Exporting Map Sheet [17] : Oregon
   Exporting Map Sheet [18] : South Dakota
   Exporting Map Sheet [19] : Texas
   Exporting Map Sheet [20] : U.S.
   Exporting Map Sheet [21] : Utah
   Exporting Map Sheet [22] : Washington
   Exporting Map Sheet [23] : WR
   Exporting Map Sheet [24] : Wyoming
Map Document : ALWE.mxd
Map Document : BMSB.mxd
Map Document : CLB.mxd
   Exporting Map Sheet [1] :   U.S.
   Exporting Map Sheet [2] :  WR
   Exporting Map Sheet [3] : Arizona
   Exporting Map Sheet [4] : Arkansas
   Exporting Map Sheet [5] : California
   Exporting Map Sheet [6] : Colorado
   Exporting Map Sheet [7] : Idaho
   Exporting Map Sheet [8] : Iowa
   Exporting Map Sheet [9] : Kansas
   Exporting Map Sheet [10] : Louisiana
   Exporting Map Sheet [11] : Minnesota
   Exporting Map Sheet [12] : Missouri
   Exporting Map Sheet [13] : Montana
   Exporting Map Sheet [14] : Nebraska
   Exporting Map Sheet [15] : Nevada
   Exporting Map Sheet [16] : New Mexico
   Exporting Map Sheet [17] : North Dakota
   Exporting Map Sheet [18] : Oklahoma
   Exporting Map Sheet [19] : Oregon
   Exporting Map Sheet [20] : South Dakota
   Exporting Map Sheet [21] : Texas
   Exporting Map Sheet [22] : Utah
   Exporting Map Sheet [23] : Washington
Map Document : EAB.mxd
   Exporting Map Sheet [5] : Denver Area
   Exporting Map Sheet [6] : Idaho
   Exporting Map Sheet [7] : Iowa
   Exporting Map Sheet [8] : Kansas
   Exporting Map Sheet [9] : Louisiana
   Exporting Map Sheet [10] : Minnesota
   Exporting Map Sheet [11] : Missouri
   Exporting Map Sheet [12] : Montana
   Exporting Map Sheet [13] : Nebraska
   Exporting Map Sheet [14] : Nevada
   Exporting Map Sheet [15] : New Mexico
   Exporting Map Sheet [16] : North Dakota
   Exporting Map Sheet [17] : Oklahoma
   Exporting Map Sheet [18] : Oregon
   Exporting Map Sheet [19] : South Dakota
   Exporting Map Sheet [20] : Texas
   Exporting Map Sheet [21] : U.S.
   Exporting Map Sheet [24] : WR
   Exporting Map Sheet [25] : Wyoming
Map Document : EGVM.mxd
   Exporting Map Sheet [20] : Utah
   Exporting Map Sheet [21] : Washington
   Exporting Map Sheet [22] : WR
   Exporting Map Sheet [23] : Wyoming
Map Document : GH.mxd
Could not open Map Document : GH.mxd
Please check whether the Map Document is being used by other application(s).
Could not load Atlas Extension from Map Document : GH_Melanoplus_Sanguinipes.mxd
Could not load Atlas Extension from Map Document : GM.mxd
Could not load Atlas Extension from Map Document : GWSS.mxd
Could not load Atlas Extension from Map Document : JB.mxd
Could not load Atlas Extension from Map Document : LBAM.mxd
Could not load Atlas Extension from Map Document : MC.mxd
Could not load Atlas Extension from Map Document : MXFF.mxd
Could not load Atlas Extension from Map Document : SFTM.mxd
Could not load Atlas Extension from Map Document : SL.mxd
Could not load Atlas Extension from Map Document : SYM.mxd
Outcomes
