r.mordoff
Popup Template Display Field Alias
Discussion created by r.mordoff on Dec 7, 2011
Latest reply on Dec 8, 2011 by khutchins-esristaff
I'm using the popupTemplate for displaying attributes for a feature and I'm trying to display the alias as the label, figured it should be pretty easy... Here is what the docs says about it:
fieldInfos
[INDENT]<String> label  The label to display, the default value is the field alias.[/INDENT]
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/intro_popuptemplate.htm
Reading that I would think I should be able to declare the fieldInfos as follows and the alias should be displayed as the label:
var popupTemplate = new esri.dijit.PopupTemplate({
          title: "{address}",
          fieldInfos: [
          {fieldName: "req_type", visible:true},
          {fieldName: "req_date", visible:true,format:{dateFormat:'shortDateShortTime'}}
          showAttachments:true
But this is not the case, it still displays the field name.  Below is a sample I altered to show what is happening.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the
    samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
      San Francisco
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"/>
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{
      padding: 20px 20px; } #map{ padding:0;}
    </style>
    <script type="text/javascript">
      var dojoConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5">
    </script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("esri.dijit.Popup");
      var map;
      function init() {
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        //setup the map's initial extent (World View)
        var initExtent = new esri.geometry.Extent({
              "xmin":-13631589,
              "ymin":4549150,
              "xmax":-13630075,
              "ymax":4549635,
              "spatialReference":{"wkid":102100}
        //define custom popup options
        var popupOptions = {
          'markerSymbol': new esri.symbol.SimpleMarkerSymbol('circle', 32, null, new dojo.Color([0, 0, 0, 0.25])),
          'marginLeft': '20',
          'marginTop': '20'
        //create a popup to replace the map's info window
        var popup = new esri.dijit.Popup(popupOptions, dojo.create("div"));
        map = new esri.Map("map", {
          extent: initExtent,
          infoWindow: popup
        //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        //define a popup template
          title: "{address}",
          fieldInfos: [
        //create a feature layer based on the feature collection
        var featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
          infoTemplate: popupTemplate,
          outFields: ['req_date','address']
        featureLayer.setDefinitionExpression("address != ''");
        dojo.connect(featureLayer,"onClick",function(evt){
           map.infoWindow.setFeatures([evt.graphic]);
        map.addLayer(featureLayer);
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      dojo.ready(init);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"
    style="width: 100%; height: 100%; margin: 0;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"
      style="border:1px solid #000;padding:0;">
      </div>
    </div>
  </body>
</html>
When I identify it still shows the field name as the label, attached is a screenshot. I would expect it to show Request ID and Request Type as defined in the service.  Am I doing something wrong or is this a bug?  Is there an easy fix for this?
I know I'm able to declare the label explicitly for the fields, but I don't want to have to maintain those when clients want them changed.
Ryan
Outcomes
