Hello Eric,
Thanks for the answer.
If you zoom in the image, you will see that some break line in the raster output and it doesn't look smooth. I've done interpolation with the same points with IDW and it is smoother than ordinary kriging.
Also, I checked my data points and I found out that they don't have normal distribution. So, I used Simple kriging to normalize the data. I've attached the result of simple kriging. If you compare these two images, you will see how the output of simple kriging smoother than ordinary kriging. I am wondering if the problem is normal distribution of the data or not?
Thanks again,
Mina
