melissatalley
Table to Table after Python Script in model not working correctly
Discussion created by melissatalley on Nov 9, 2011
Latest reply on Nov 10, 2011 by melissatalley
I have a script in my model which outputs a text file. The model then takes this text file and performs a table to table conversion on it to make a dbf.
When I run my script manually, not as part of my model it outputs the text file fine, I'm then able to manually do table to table and everything works perfectly.
When I run my script in my model the text file appears to output fine, but after table to table is performed one of my columns comes in with the right header name but all zeros while the other column comes in exactly perfect. I need this first column however to preform my join.
What could be causing the difference in behaviors?
Thanks for any ideas anyone may have!
Outcomes
