Adding Navteq divider restriction to Network Dataset
1331
10-21-2011 10:32 AM
JohnatanRojas
Hello.
Navteq street data includes an attribute that models dividers on a single link/arc, it is used to prevent right turns because a divider exists.
check the attached image...., the left side is the real life, and the right side is how navte models it. The "Street" with the divider is modeled as a single arc with dir travel = Both
It is posible to model a restriction in the network dataset using the divider attribute??
Or we have create a polyline for each intersection to model invalid turns?, in the example it would be 4 additional turns??
I would aprreciate any help or insights from you experts....
JoeBorgione
Hello.
Had to take a second look at your images; obviously, you're not in the U.S.!  😮
Anyway, I'm not at all familiar with Navtech data, but could you augment it with an additional line that has a one way restriction to the correct direction of travel?
