MBoucher21
Resetting Raster calculation limits
Discussion created by MBoucher21 on Oct 19, 2011
Latest reply on Apr 16, 2012 by MBoucher21
I�??m having a problem with an Arc Hydro tool that uses rasters. Some setting is limiting the raster or calculation limits in the data frame.
The attached image shows that the subwatershed (lite green) delineation is limited to a rectangular area. The sub-watersheds should cover the red polygons. This process uses rasters then converts them to polygons so I know the problem is in the raster calculations. This tool worked earlier today, but I had to rerun it and now it has problems.
I recall there being a command to reset something that would fix this but I can�??t recall it or figure it out again. Do you know off the top of your head.
Outcomes
