jgarcia14
asc2sde fast create then super slow append
Discussion created by jgarcia14 on Oct 7, 2011
Latest reply on Oct 12, 2011 by jgarcia14
Hi all,
I am running into a problem with Asc2sde and I hope somebody can help me.
I am loading records to an ArcSDE table using asc2sde.
When I use asc2sde �??o create records are loaded very fast:
Results:
        Records read: 20839404
        Rows created: 20671607 (167797 rejected)
         Insert time: 56.77 min (6068.73 TPS)
        Elapsed time: 1.283 hours
Then I create spatial and table indexes, test it and everything works fine.
Then I drop the table indexes using sdetable -o delete_index. I also run sdelayer �??o load_only_io
and then I run asc2sde �??o append and this is the result I get:
Results:
        Records read: 5000
        Rows created: 4990 (10 rejected)
         Insert time: 9.906 hours (8.40 TPM)
        Elapsed time: 9.906 hours
Is there a way I can speed the appending up to where it is comparable to the initial load?
I am using ArcSDE 9.3.1 on on SQL Server 2008 SP2 (10.00.4000) Enterprise Edition
Please find attached a describe long of my sde layer.
Outcomes
