Hi all,
I'm having issues consuming a ArcGIS Server Map Service (with Network Analyst enabled) using the Find Route tool in ArcMap. When I attempt to configure the Find Route tool to use the service it shows a 'Cannot Setup Routing Service' error message. I can't see anything within the logs either.
I'm new to NA so I'm a bit stuck as to what the fault is. Any guidance would be much appreciated.
My setup is as follows:
* I have a Network dataset in an ArcSDE 10 SP2 database.
* I have proven that the NDS in SDE works correctly by using it directly as input to the Find Route tool. In this case, the route and directions are produced correctly.
* My next step is to try to consume the NDS as a service. I have created an MXD by dragging the NDS from SDE into the map. I've clicked Yes , when prompted to bring in related datasets (i.e. junctions \ centrelines) and have used the Network Analyst tool to create a Route layer within the map. The route layer seems to be stored within the MXD and has a GUID data source. The map has no selected features \ resolved routes in it. I've then published this MXD as a Map Service to a local instance of ArcGIS Server 10 SP2 with the Network analyst capability enabled. I can view the REST end point and it shows a route method. But as soon as i try to consume the service in ArcMap via the Find Route tool it shows the aforementioned error.
Any ideas?
cheeres
Dan
Any ideas?
cheeres
Dan
Sincerely, Doug Schenk
We have seen this error reported previously by those working with data from the DVD. You have copied the data from DVD to local machine, correct? All parts of the data were downloaded and reference the original location of data as existed on disk? For instance the streets network dataset uses a number of other SDC datasets and if it or the datasets have been moved, relative to their original location, then errors will occur.
If you still are experiencing this error when accessing data from local machine and are current in ArcGIS maintenance, please submit a support request via Esri Support site.
Cheers,
Denise
Denise
Thanks for reporting this and for your patience.
Deelesh Mandloi
just wanted to ask if this issue has been solved or if there exists a workaround? I have the same problem within ArcGIS 10.2. I created a Network Dataset an published it as a service, but when I set this (my own) service as Routing Service instead of the ArcGIS Online Routing service, an error-popup "Cannot setup routing service" appears.
Thanks in advance for all kinds of hints!
Sebastian
EDIT: Like dingle wrote above, the solution is to connect to the services with the network analysis funtion as user and not as an admin or publisher. Then you can use you own service for routing. I don´t understand why because the admin-connection is the connection with the most-rights but anyway. It works and thats fine.
