exportwebmap service error--map size is missing
2003
09-01-2011 07:48 PM
zhuzheng
hi,guys
    i can not run the exportwebmap gp service successfully in the service directory. this error tip is : map size is missing. but i can not find the map size parameter. The detailed error info is in the attachment files.
the json code of web map is :
"baseMap" : {
"title" : "My Basemap",
"baseMapLayers" :  {
"url" : "http://localhost:6080/arcgis/rest/services/Ex3print/MapServer",
"mapOptions" : {
"extent" : {
"xmin":2473180.9606,
"ymin":679774.7489,
"xmax":2500969.998,
"ymax":708732.566,
"scale" : 44898,
"exportOptions": {
"dpi" : 100,
"outputSize" :  {
500,
500
Does everyone know this?
thank you very much.
SrinivasVinnakota
Zhu,
Try the modified JSON request below. You can compare this with your original request to see the differences.
Also consider running the JSON through a validator to make sure that a correct request is sent to the print service.
"baseMap" : {
"baseMapLayers" : [
"mapOptions" : {
"extent" : {
"ymin":679774.7489,
"xmax":2500969.998,
"ymax":708732.566
"scale" : 44898
"exportOptions": {
"dpi" : 100,
"outputSize" : [
500,
500
zhuzheng
hi�?thanks for your repense.
i use your json code , i meet the error which i have posted in another post named "how to run exportwebmap service? "
can you see it? thank you very much.
