Text halo selective mask on background layer
4367
6
09-01-2011 01:01 AM
GuillaumeMOCCAND
New Contributor III
Dear all,
i wonder how i can get a result as shown on the attachement.
I want to use the text halo as a mask on choosen layers, ex :
- the halo should mask a part of the road lines (black part of the line symbol)
- the halo should NOT mask the water layer
I thank you in advance for your idea (a have ArcInfo, with PLTS / Production Mapping).
Guillaume
deleted-user-L16PxV86KH8Z
Hi Guillaume,
I had the same kind of problem on a project few months ago.
I agree with you that it would be great to have a solution in order to do this!
I have never tried PLTS Mapping so maybe it's possible with this solution, but I'm pretty sure you can't do this with Esri "core" products.
JC
Bo_King
Occasional Contributor III
If you convert your labels to annotation, then masking can be handled with the use of the Feature Outline Masks tool and the ArcMap Advanced Drawing Options settings.  The standard ArcGIS workflow is outlined as Using masking.
GuillaumeMOCCAND
New Contributor III
for the condition "should not mask the water" it is OK
But for the road lines i may have the following case :
the road style can be a 2 levels line : red line over a larger black line.
In my small exmple the symbol is a white line over a larger black line.
I want the mask to act :
- on the black part of the line symbol
- NOT on the colored part of the symbol (either it is red, yellow or white)
My understanding of the ESRI Capabilities is that it makes a new layer (i do not want to manage an additional layer) and that it acts over the full layers symbology, while i need it to act over only a part of the symbol.
An other solution could be to manager 2 layers from the same Feature Class in order to mask only the black part of the symbol as a single layer. But doing so we have so many layer and so many mask.
am i wrong ?
Guillaume
Bo_King
The Advanced Drawing Options will allow you to mask only selected symbol layer, so yes, you are able to mask only black part of the line symbol.
Converting labels to anno creates a new annotation feature class, and creating Feature Outline Masks creates a new polygon feature class.  These features are necessary to leverage the Advanced Drawing Options functionality.  I think you will find that the management of these additional features will will be well worth the benefit of masking to your cartographic output.
GuillaumeMOCCAND
New Contributor III
I found this function ... i could have found it by myself. Thanks for the time i saved.
I still have 1 questions regarding the use of mask :
How should i used the "levels" value ?
I tried to not mask the red part of this symbol (see attached image). The red part of the symblol is the "Layer" 2 is the symbol. My map Layer is rendered with symbol having 1, 2 or 3 symbol Layers.
when i try set use a value (i tried from A to 18), i get no results and when i re-open the "advanced drawing option ..." window, the "Enable to associate levels to masked layers" option is no longuer selected
When this issue will be solved i would have only on thing to manage : mask management in letters with holes such as "O", "D" ...
Thanks again for your help.
Guillaume
by Anonymous User
Not applicable
Did you ever find any infor on how to use the "Enable to associate levels to masked layers" option?
Doco is lacking and nothing around online that I can find.
