I have a dataset where the entire address is broken up in different columns such as house number, direction, ect.... (see attached sample of data). When I go to geocode the only options for the data are address, city, state, and zip? Is there any way to have more fields to select, or must I concatenate all the fields so they fit under the address part? I prefer not to concatenate as I think the results will be more accurate.
What is the best way to geocode these addresses in this format?
I�??m trying to do this now, and I am concatenating, problem is that not all the fields have values and I end up with leading/trailing spaces or double spaces. How can I get it to concatenate but skip over the empty fields?
Small sample set attached.
