amcclune
Holes in Polygon
Discussion created by amcclune on Jul 7, 2011
Latest reply on Jul 7, 2011 by cfdirt
I am using the 'Eliminate Polygon Part' tool to try and remove the holes that I currently have in my polygon. However I have come across a stumbling block and have found not all my holes are being filled. Even using the 99 percent elimination part (100 is not in the valid numeric range) it still does not remove the holes. All the holes that are not being filled in are at the edges of the polygon. I am trying to do this so that it can be incorporated into an automatic process so using the Editor tool is not really ideal. Attached is an example of my problem. Does anybody know how to get around this?
Outcomes
